Creates a tracking entry for the specified route. When this route becomes unreachable, this entry is considered to be failing.
| vlan_name |
Specifies the name of a VRRP VLAN. |
| vridval |
Specifies the VRID of the target VRRP instance. To display the configured VRRP router instances, enter the show vrrp command. |
| ipaddress |
Specifies the IPv4 or IPv6 prefix of the route to track. |
| masklength |
Specifies the length of the route's prefix. |
N/A.
The route specified in this command might not exist in the IP routing table. When you create the entry for a route, an immediate VRRP failover might occur.
VRRP tracking is not supported on MPLS LSPs.
The following command enables IP route failure tracking for routes to the specified subnet:
configure vrrp vlan vlan-1 vrid 1 add track-iproute 3.1.0.0/24
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the VRRP feature, see the Switch Engine v33.1.1 Licensing Guide document.
